It is currently Wed Jan 15, 2025 4:42 pm
Post subject: Re: Termostat si sonde apa (D127) Posted: Tue Jul 12, 2011 10:21 pm |
Post subject: Re: Termostat si sonde apa (D127) Posted: Wed Jul 13, 2011 4:19 pm |
Maxim, do you know what car this fits?
maxim
Post subject: Re: Termostat si sonde apa (D127) Posted: Wed Jul 13, 2011 4:32 pm |
Hi Stef! Yes. I'm fitting WAHLER 4174.82D on my 244. All other - analogue for it. p.s. analogue for temp sensor - not found it's marked 5521
Post subject: Re: Termostat si sonde apa (D127) Posted: Wed Jul 13, 2011 5:29 pm |
No no, I'm asking, what is the car that this thermostat was produced for? Was it made especially for ARO, or for a japanese car? If so, which?
maxim
Post subject: Re: Termostat si sonde apa (D127) Posted: Wed Jul 13, 2011 6:44 pm |
This is a very large number of ... I try to give the most extended ones: CITROEN JUMPER 230/230P/244 RELAY/RELAY II 2.8 HDi 128HP FIAT DUCATO 2.8 HDi PEUGEOT BOXER 2.8 HDi i.e. all with IVECO 8140.43S engine. Also: IVECO Daily I, Daily II, with engines: XY8, 149 A2.000; 149 A4.000, 8144.61, 156 C.046, 138 C2.048; 149 C1.000, 146 C3.000, 831 A2.000; 831 B.000, 831 D1.000, ALFA ROMEO AR 6 (280) 2.4 TD [8144.21.220] 92 HP OPEL Movano 2.5 D [S8U 770] 80 HP SEAT 131 2.4 Diesel [8144.61] 72 HP Also: for all engines FIAT/IVECO/OHM 80-series, ex. - FIAT 8035.04, 8040.01, etc... Also: for SOFIM engines...
Post subject: Re: Termostat si sonde apa (D127) Posted: Wed Mar 28, 2012 10:38 am |
KAROLOKW
Post subject: Re: Termostat si sonde apa (D127) Posted: Thu Mar 29, 2012 1:19 pm |
cred ca sonda aia de temperatura o am eu da trebuie sa verific prin cutia de suruburi
