It is currently Fri Dec 27, 2024 4:14 am
 Page 1 of 1 [ 5 posts ]
 Post subject: "ENGINE THAT NEVER HAPPENED"
PostPosted: Thu May 21, 2015 6:26 am
Probably "cup of patience was exhausted," or something else, but from saturday started the fuss about the realization of the idea "ENGINE THAT NEVER HAPPENED". Sorting, cleaning, washing, Troubleshooting of parts the "dead" and "before the infarct" engines... They will be the "ENGINE THAT NEVER HAPPENED"... What is it ???
...Development of Brasov d111/115/124/127 - from 95x110 mm once in 102x115 mm.
Fiat 80x0.0y - 95x110 mm, then 100x110 mm (100x115 mm), then 103x110 mm (103x115 mm) and ended on 104x115 mm...
Came the idea - to fitting the pistons set 100 mm from Fiat on Brasov. This - and not Brasov (it was not a such dimension) and not Fiat (differences in the construction, because Brasov - it no copy, and the license of Fiat!).
Everything started to happen!
 Post subject: Re: "ENGINE THAT NEVER HAPPENED"
PostPosted: Fri May 22, 2015 6:41 am
Preparatory works...
PostPosted: Fri May 22, 2015 6:44 am
...more...
PostPosted: Fri May 22, 2015 7:05 am
...two engine block ready for boring up to 100 mm...
...will attempt to adapt this injection pump...
PostPosted: Fri May 22, 2015 8:01 am
Very interesting title :D - the unique Brasov !
